Daveyd
I know I know OSB3 board is ***** for tiling onto. If only I'd known at the time! Ah well its now pretty well impossible to rip it up and start again SO.....
How would I best prep my bathroom floor before laying my ceramic tiles?
I've got some good quality flexible adhesive and also some membrane matting (thin material type)
The OSB is 18mm and has only a very tiny amount of visible flex with the fat man test. Another concern is that there is a bit of a ridge where it is higher than the rest maybe 20mm higher.
One thought is to use self levelling compound straight onto the OSB then stick the membrane using PVA. Then tile.
OR Lay plyboard, prime then membrane and tile (but the ridge might still be a problem)
My favourite option is to use SLC to get a nice even flat floor but what are peoples experience of using this stuff straight onto OSB? Would the small amount of flex pose a problem?
What do I do!?!?
Any help or advice much appreciated!
Dave in Cornwall
What do I do!?!?
Dave in Cornwall
