Hi I’m fitting a Nova Frameless 1000 x 800 Sliding Door Shower Enclosure with a low profile shower tray that you lay on sand and cement. I’ve fitted Some aqua boards and where I’m fitting the enclosure the walls are slight out of plum by about 10-15mm.
I’ve already primed the walls with Mapei primer g and taped the joints. I need to skim over the tape with adhesive and then I’m going to apply Mapei aquadefense on top.
My question is can I bulk out the wall at the bottom with tile adhesive under the coat or aquadefense before I fit the tray?
Thanks Ben
Thanks Ben
