Discuss Outside corners in the Canada Tile Advice area at TilersForums.com.
Mitring external corners recently described by a member as They black art!’ 😂
craigy
98
US
My cheap MK saw's table does angle up to mitre but it doesn't leave a great finish on the one piece I tried. It seems to chip more when the tile is cut finished side down. I can buy bullnose in a different tile that may look ok since they would only be the door jams and extend inside the door about an inch.
Tony_C
528
Glasgow
Hi Craig, sounds like you may be just cutting too much into the tile and creating a really thin cut at the end into the glaze which is causing the glaze to chip as its being cut from behind. You want to try leave a 1mm or so of the biscuit of the tile edge you are cutting to mitre so you don't actually cut into the glaze or chip it.
Here is a video of a fellow american explaining it which will probably help better. You can skip to 3 minutes in if you don't want to watch it all.
craigy
98
US
Thank you Tony, I will try again. I also found some bull nosed tiles that will look very close. They all will be on a different plane than the rest, just around the door jamb so only about an inch will be inside the door. I will have to buy one more box of the wall tile to mitre if I go that root and only end up using only two of the tiles.
Tile trim all the way 😉😉
Reply to Outside corners in the Canada Tile Advice area at TilersForums.com
A question about mitering and matching epoxy colour I'll be working with some pinkish matt...
Hello, First post here on the forum. Thanks for reading! I have an application for 1"...
Hi I would like to use some indoor tiles outside on the top of my fish pond wall, the tiles I am...
Hi, new to forum and first post, after some advice. Recently had the chamber of my fireplace...
US
Outside corners
    Votes: 9 6.2%
    Votes: 13 8.9%
    Votes: 11 7.5%
    Votes: 44 30.1%
    Votes: 17 11.6%
    Votes: 34 23.3%
    Votes: 3 2.1%
    Votes: 20 13.7%
    Votes: 18 12.3%
    Votes: 15 10.3%
    Votes: 7 4.8%
    Votes: 3 2.1%
