Stalbot
Hi all,
I am looking for some advice, I have an outside area that required tiling, it was concreted a few years ago and has been exposed to the elements. I was planning on power washing the concrete before starting as it has gone bit green in areas due to moss and algae! The tiles I am using are standard 1 foot porcelain tiles with a slight ripple on the edge.
I have been putting the job off for a while now as I am a bit worried about the ground being completely dry, very hard to achieve in the UK, but not sure if it is completely necessary if I use a powder water based mix.
I was planning on power washing, then giving the concrete a coat of acrylic primer before starting the job, do I need to do this, or is it over kill?
I was planning on using a rapid set flexible adhesive to lay the tiles, may need to thicken it in areas to make up levels - is this acceptable?
If anyone has any recommendations on the best adhesive to use & pointers on preparing the area it would be very much appreciated.
many thanks
Simon.
many thanks
Simon.
