Discuss Overboarding Karndean floor in the Canada Tile Advice area at TilersForums.com.
burncross
Got a job coming up.
A new kitchen has been fitted over the top of the original Karndean flooring. So it would be very difficult to remove the Karndean.
Its a timber floor (floor boards) with Plywood poss 3 or 5 mm, then the Karndean.
So I am thinking instead of trying to spend hours if not days trying to remove, simply overboarding with 6mm Hardiebacker, screwed down with 30mm screws. Then install the small format tiles using a good quality adhesive (Weber rapid set flexible).
Is this the way to go?
L
LM
I reckon it would be difficult to lift the ply, could be screwed down? and kitchen units and kitchen island are fitted directly on top
Speaking with absolute confidence from experience as a time served LVT installer there is no way the underlayment is screwed down, in fact I'd wager that it's hardboard and it'll have been twist nailed or even stapled down. I would screw right through to the subfloor along with sticking down my preferred over board. The LVT won't come away from the hardboard but the hardboard coukd come away from the ply or chipboard sub base.
Bill
I have Karndean in my house and the plywood substrate was definitely screwed down and then the screw heads were covered by an Ardex compo...........
L
LM
Your lucky you had a competent floor layer. The Ardex compound was Feather finish. For soft flooring hardboard is acceptable and not many installers would spend the money or go to the effort of having to use a saw to cut a board when you can use a knife on a much cheaper board that's quicker to install and will do the job. Never mind the time involved to screw down all the boards. Vinyl floors don't "suck" the board off the substrate the same way as tile adhesive does.
Kyle Knowles
1,108
Widnes
I know a couple of kahndean fitters who use 3mm ply cut with a knife and nailed down and u really wouldn't wanna tile over that
Reply to Overboarding Karndean floor in the Canada Tile Advice area at TilersForums.com
I am sure someone will know a good practice solution. We started a wetroom last year and then...
Hi guys, I'm new to tiling and looking for some advice. I'm practical and usually pretty good...
    Votes: 14 9.5%
    Votes: 44 29.7%
    Votes: 17 11.5%
    Votes: 35 23.6%
    Votes: 21 14.2%
    Votes: 15 10.1%
