Tile Shop
Hiya.
In a few months we plan to rip the bathroom out and redo the lot. As I need the practice and want to get everything right, I am going to reboard all the walls with Marmox, tile it and get a plumber to fit a new bath suite.
The stud walls shouldn't be a problem. Take all the old plasterboard down, add a few noggins and screw the marmox in.
But there is also an external window wall. When the old tiles come off, it will be plaster on [i guess] rendered breeze block. What is the best procedure to fix the marmox? Does the plaster need to come off completely, or can I just screw through the plaster and anchor it into the block behind?
Not looking to cut any corners and don't mind any messy work as long as its done right.
