Discuss overlaying chipboard t & g in the British & UK Tiling Forum area at TilersForums.com.
peegee tips
If tiling on to a solid t & g chipboard floor in a small bathroom & en-suite new build, would it be ok to overlay with 6mm hardi fixed with flex adh & screwed. Then tile with flex adhesive & grout with gt1?
will the flex adh adhere to the chipboard or is it just to fill the voids behind the hardi & allow for expansion?
Just that the customer wants to keep the height down.
Thanks.
grumpygrouter
In my opinion, the use of hardie in this situation depends entirely on the size of the floor area. if small as you indicate it will be fine. The adhesive bed only needs to be applied using a 6mm notch trowel and is really just to fill the voids but obviously it will stick the board to the floor as well. Personally I would prefer Hardie to ply in this situation.
peegee tips
Thanks for your replys guys.
The rooms are only 3 & 4m2 each.
No thresholds fitted or other flooring in yet either.
The Hardie is looking favourable i feel, but i've heard of other tilers using Ditra also, is this a good practice?
Not forgetting tiling straight to the chipboard with 2part flex also.
What would be the pro's & cons of using ditra & 2part flex in this situation?
grumpygrouter
Ditra will do nothing to help with any deflection. It is designed to provide protection form lateral movement created by contraction/expansion of the substrate. The general problem with chipboard is that it is unstable in a number of ways. 1 of them being the potentional for the "chips" to break away from the board. Using ditra only will still not protect for these pieces breaking away. Hardie on the other hand is mechanically fixed with screws as well.
You can tile straight onto chipboard with appropriate adhesive and I have done it myself, but my preferred method now is to overlay with 6mm Hadiebacker 250, glued and screwed.:thumbsup:
Reply to overlaying chipboard t & g in the British & UK Tiling Forum area at TilersForums.com
Hello all, I could do with some advise if anyone would kindly help me. first of all, I’m not a...
Edd The Tiler
E
Hi, I'm currently renovating and my next job is tiling. I have new T&G 22mm chipboard screwed...
2 3
15K
I've a hall way to tile, 10m2, & have height issues with the front door, it can't be raised. I...
    Votes: 14 9.3%
    Votes: 11 7.3%
    Votes: 44 29.1%
    Votes: 18 11.9%
    Votes: 36 23.8%
    Votes: 21 13.9%
    Votes: 18 11.9%
    Votes: 16 10.6%
    Votes: 7 4.6%
    Votes: 4 2.6%
