RDTiling
Hi all.
It's been a while since I've posted due to 2016 being a very slow year, however things are starting to pick up now. It got to a point in March where I considered shutting up shop, but I'm glad a persevered with it.
It's been a while since I've had a job with painted plaster (only on one wall). I put about 12 pieces do duct tape on various bits of the paint, left them about 4 hours and upon peeling them off the paint remained firmly on the wall.
I had thought about going down the sanding route, which I will if necessary.
As a bit of brainstorm, does anyone foresee any stumbling point if I were to:
1. Score the wall with a Stanley blade
2. Prime wall with Acrylic Primer
3. Roller on an SBR Slurry coat and then tile onto slurry coat
Unfortauntely, I can't dot n dab the wall, as if I did this - and after tiling, it would cover the oak window sill they have just had fitted (as part of the new window being installed). The joiner has only left about 15mm of window sill overhanging the wall.
Any thoughts, suggestions are welcome.
Rich
Rich
