Discuss painted plasterboard in the British & UK Tiling Forum area at TilersForums.com.
CJ CERAMICS
personally i would never tile over any form of paint as the adhesive tends to bubble the paint and loosens it but you cant see it happening. if the job allows replace the boards and prime them. if the customer is not happy with that screed a small area with the adhesive leave for an hour or so then scrape it off i would be very suprised if the adhesive does not remove the paint very easily. by the way which adhesive are you planning to use?:sunny:
CJ CERAMICS
ok so are you planning to use the cheap addy for the removal of the paint? if so i would way up the time scale of removing the paint and the cost of the addy as to the cost of replacing the boards and price accordingly. but for me i would rather replace so that you can be as sure as you can that there will be no problems after. best to explain this to the customer in the end its your reputation thats being looked at if things go wrong because of the customers wishes. hope this helps.
chris
Reply to painted plasterboard in the British & UK Tiling Forum area at TilersForums.com
    • Useful
Hi, Im looking for a recommendation for a liquid tanking. I have to use a liquid tanking...
Some helpful advice/opinion would be appreciated... Existing tiles on walls, some of the walls...
Hi, Soon to lay 500mm sq tiles onto screeded hall/kitchen floor 25m2. Hall floor has vinyl...
    Votes: 9 5.6%
    Votes: 17 10.6%
    Votes: 11 6.8%
    Votes: 44 27.3%
    Votes: 21 13.0%
    Votes: 38 23.6%
    Votes: 4 2.5%
    Votes: 3 1.9%
    Votes: 22 13.7%
    Votes: 19 11.8%
    Votes: 17 10.6%
    Votes: 8 5.0%
    Votes: 5 3.1%
