Discuss painted walls in the British & UK Tiling Forum area at TilersForums.com.
MIKE1
I am about to do my second paying job just wanted to double check a few things since never tiled onto a painted surface before
Tiling onto a painted wall ,will do tape test and then if paint comes off sand and score the wall, would you then seal the wall before tiling or will it be ok just to tile straight onto. I was going to use tub stuff so can I use any sealant or would you guys recommmend one.
If the paint is ok would you still score it anyway and then seal ?
robbo
if you are going to prime use something like this
BAL Prime APD
A modified acrylic polymer dispersion for use as a primer for a variety of backgrounds/bases prior to fixing ceramic tiles, mosaics and natural stone and prior to the application of levelling compound and the BAL WP1 TANKING SYSTEM. BAL PRIME APD isolates products containing calcium sulphate such as gypsum plaster and anhydrite screeds from cement-based adhesives, thus minimising the risk of reaction between the two materials.
Also suitable for use on cement:sand rendering, blockwork, plasterboard, cement:sand screeds and timber. It also provides surface strength to friable surfaces and reduces the porosity of porous backgrounds/bases, thus preventing the formation of air bubbles and prolonging the flow time with levelling compounds and extending the open time of tile adhesives. The primer is blue in colour to help ensure that a complete and even coating is obtained.
Reply to painted walls in the British & UK Tiling Forum area at TilersForums.com
Hi, can anyone advise me on how to prep a painted brick or block wall for tiling? Do I just wash...
What would you guys do with the walls to prep for fitting 1200mm x 600mm Onice Verde (Porcelain)...
Hi, 1200 wide tray and tiling shower enclosure recess with metro tiles where the 1200 wide...
painted walls
    Votes: 9 5.6%
    Votes: 17 10.5%
    Votes: 11 6.8%
    Votes: 45 27.8%
    Votes: 21 13.0%
    Votes: 38 23.5%
    Votes: 4 2.5%
    Votes: 3 1.9%
    Votes: 22 13.6%
    Votes: 19 11.7%
    Votes: 17 10.5%
    Votes: 8 4.9%
    Votes: 5 3.1%
