Discuss Painting over tanking in the Australia Tiling Forum area at TilersForums.com.
N
newreno
I hope this is the right section... It's not about a wet room (or even tiling directly...), but hopefully someone here will know the answer.
We're renting a place that gives us free rent in exchange for renovation work. The owner remodelled the bathroom on a structural level before we came in, so we had a basic plasterboard canvas. They also tanked around the shower and bath, including up the walls with those units.
I've now finished tiling the walls and would like to paint above the tiling, but the tanking above the bath goes above where the tiles end. I guess I can't paint directly onto the tanked area? What would you suggest as a workaround? Lightly sanding off the tanking material? Putting a very fine layer of finishing plaster over the top and then painting on that? Something else?
Thanks lads...
N
newreno
It's not my place and I'm doing the work myself. No need to run up extra cost and time investment on someone else's account... :) The landlord is happy to have only the minimum done around the bath and shower, i.e. a good amount of tile above both topped off with a neat trim. The rest will be painted in a clean white.
N
newreno
It's quite grainy. It almost feels like sandpaper when you run your fingers over it.
Sanding it down lightly isn't an option then? I could probably do a very light skim myself but it wouldn't be my first choice unless essential! But much quicker and cheaper (for me) than tiling to the top. There are also tiles on two other walls for the toilet, sink and towel rail (it's a strange shaped bathroom) so it'd look strange to tile to the ceiling on the bath and shower walls but not on the others, as well.
N
newreno
Great, thanks for the help. Will the plaster stick to the tanking, or will I need to prepare it in some way first?
I'm still not 100% on why the sanding wouldn't work though because the tanking seems almost like a layer that could be rubbed off... If I can get back to the original plasterboard then I'll be laughing... But I'll go with the wisdom and consider the skimming option as the next best thing! :)
Reply to Painting over tanking in the Australia Tiling Forum area at TilersForums.com
I'm embarking on tiling a kitchen, wall-to-wall (under washing machine etc). most of the floor...
We recently finished a bathroom renovation where the two builders who did the bathroom also did...
Hello, i hope someone can give me some advice please. I’m planning on tiling our bathroom walls...
    Votes: 14 9.5%
    Votes: 44 29.7%
    Votes: 17 11.5%
    Votes: 35 23.6%
    Votes: 21 14.2%
    Votes: 15 10.1%
