Discuss palace in the UK Tiling Forum area at TilersForums.com.
Dan
Admin
Staff member
5,088
1,323
Staffordshire, UK
Been using Bal Grip all week. Great grab on it, git to get off your hands! I gotta throw my new trowl away too coz i fogot to clean it before i rushed down the bakers for lunch, DOH!!
Rub it all off with your rubbing stone :) That'll teach you!
UKTT Darren
TF Official Sponsor
Subscribed
195
828
North East
I have used palace super grip class b adhesive for walls for ages now and find there is no stronger tub gear out there, and ive tried them all I used to do a demo in the training centre with a 9mm 30x30 floor tile, half fill the back, stick it on the wall, draw a line under it, leave in for 30 mins and bring everyone back to see if it had moved, same place on the line every time, payed £4.50 direct from palace, used their multi flex as well under a tenner done the job with no problems to date, Bal is obviously a great make but is getting on the expensive side and if your supplying materials can make the difference between getting the job or not, Bal best for grouts though
L
Leatherface
Cheers Darren - would like to see more posts by people like you - forum can be a bit bleak sometimes - many newbies and not so many experienced.
Cheers :) :) :) :)
UKTT Darren
TF Official Sponsor
Subscribed
195
828
North East
Palace used to have a bad name and sometimes names stick, there tub gear is quite stiff to trowel but you get used to it, its the no battens, non slip properties that make it exceptional, just stike up your level tile line half way up the wall and tile straight along it, level it off with your spirit level and then tile down to the floor
UKTT Darren
TF Official Sponsor
Subscribed
195
828
North East
Ive put ceramic tiles on plasterboard walls over 30x30 with tub stuff, because the walls are flat, if going on to uneven surfaces with any 45x45 or 60 x30, the descrepencies in the wall will require you to use a larger format trowel like a floor trowel on the wall, i would use a cement based as they are much stronger in this case, be sure to prime any new plastered surface if using cement adhesive as cement and plaster react together causing failures, use a good acrylic primer like BAL apd
Reply to palace in the UK Tiling Forum area at TilersForums.com
  • Sticky
  • Poll
Which Tile Adhesive and grout brand did you use the most in the last 12 months? And also...
5K
This is the Number 1 Best Tile Adhesive from 2007 to 2021 recorded (almost) annually Discussion...
Hi, I have a very small area (1m.sq) on an exterior doorway entrance wall to tile. I would...
palace
    Votes: 5 5.0%
    Votes: 8 8.0%
    Votes: 6 6.0%
    Votes: 25 25.0%
    Votes: 14 14.0%
    Votes: 27 27.0%
    Votes: 3 3.0%
    Votes: 2 2.0%
    Votes: 19 19.0%
    Votes: 18 18.0%
    Votes: 10 10.0%
    Votes: 5 5.0%
    Votes: 3 3.0%
    Votes: 1 1.0%
