Discuss Paramount Board in the Australia Tiling Forum area at TilersForums.com.
robbieraven
Doing an ensuite at the moment, all Paramount Board Walls! on removal off existing tiles the one side of the paramount plasterboard has come away with the tile, leaving the honeycomb exposed. There are some centre studs and the back sheet is still very sound! ie, the whole wall feels very solid still no flex. My thought was to glue some 2x4 down the entire height at 300 centres and screwed to existing stud work top and bottom. Once set I can then attach 12mm Hardie. Thoughts?
Q
Qwerty
On an identical job at the moment!
I removed all paramount core and plasterboard in the bathroom. Then retrofitted 3x2 studs at 300 centres with a header and footer and all fixed together with screws. Also drywall screwed from the hallway side into the studs and it's good to go. I was able to fix my framework to the joists in the loft and it's not going anywhere in a hurry I can tell you!
Reply to Paramount Board in the Australia Tiling Forum area at TilersForums.com
Hi all, I am in the middle of renovating my bathroom. First of its kind for me! The walls were...
I am refitting the bathroom, and have removed the (two layers of) tiles but unfortunately not...
6K
Paramount wall fix for tiling ideas? the plan is (or was) to tile floor to ceiling with 200mm x...
  • Sticky
Paramount Board
    Votes: 5 4.6%
    Votes: 8 7.3%
    Votes: 6 5.5%
    Votes: 30 27.5%
    Votes: 14 12.8%
    Votes: 28 25.7%
    Votes: 3 2.8%
    Votes: 2 1.8%
    Votes: 19 17.4%
    Votes: 18 16.5%
    Votes: 13 11.9%
    Votes: 5 4.6%
    Votes: 3 2.8%
    Votes: 1 0.9%
