Discuss Part removal of tiles in the British & UK Tiling Forum area at TilersForums.com.
diamondtiling
Hello and welcome to the forum.
You should remove all the grout from beneath the row of tiles that are staying on the walls, remove some from the edges as well, use a grout rake if you do not have a fein.
Start at the bottom and carefully remove a tile, then use a chisel to get behind the tiles and lever them off. If the tiles are on plasterboard then its likely that you will cause damage to the walls, there is not a lot you can do about that.
Explain to the customer what might happen and that you may have to re-board with new plasterboard. If you do make sure that you get your levels right so that the new and old tiles line up.
:thumbsup:
Reply to Part removal of tiles in the British & UK Tiling Forum area at TilersForums.com
Hello, Novice DIY tiler here looking for advice please. I'm replacing tiles in very small...
Some helpful advice/opinion would be appreciated... Existing tiles on walls, some of the walls...
Hi. We've had a bathroom installed with electric mat underfloor heating in a new extension. The...
    Votes: 14 9.3%
    Votes: 11 7.3%
    Votes: 44 29.1%
    Votes: 18 11.9%
    Votes: 36 23.8%
    Votes: 21 13.9%
    Votes: 18 11.9%
    Votes: 16 10.6%
    Votes: 7 4.6%
    Votes: 4 2.6%
