Discuss PCI PECILASTIC instead of ply in the British & UK Tiling Forum area at TilersForums.com.
UKTT Darren
TF Official Sponsor
Subscribed
195
828
North East
Been working with the PCI group lately at the training centre and they have a product developed called Pecilastic, it replaces ply and is only 0.8mm thick and works in the same way that ditra matting works absorbing the movement in its fibers from the surface below, what you do is go straight onto the chipboard floor with a 3mm mosaic trowel and flexi adhesive then press the sheet of pecilastic into the adhesive with a grout float then leave to dry then simply use the flexi ady to stick your tiles down, comes in 1 metre wide lenghts that is cut off a roll, costs about £7 per mt2 and cut with normal scissors.
Check out a search in google for PCI Pecilastic and have a read.
If going onto floorboards put 6mm ply down first the repeat the above
Regards
Darren:thumbsup:
DHTiling
It doesn't add strength to the floor darren............so how can it replace ply.......
Ditra...kerdi...durabase as well do not add strength to a timber floor.......each has it's own uses but not as a replacement for ply as a strengthener......
These products are
1. crack bridging membranes
2. waterproof membranes
3. uncoupling membranes
but do not replace ply as a floor strengthener.........only movement they absorb is lateral and not deflection.........:thumbsup:
UKTT Darren
TF Official Sponsor
Subscribed
195
828
North East
Hi dave, the floor will have to be made a rigid as possible i would have thought, just telling people the demo that was done off them, straight onto a chipboard floor, seems hard to believe it works with being 0.8mm thick, however they say it has been tested to death in Germany. I would have thought more for use where movement joints can occur, Its pretty new out so well see how it fairs
wetdec
I myself am a stickler for the tried and tested methods which i would personally use, still interesting to here of new products comming onto the market
Hey Darren you can only quote what you have been told, you want to point the rep to their own product data sheets before they start their bragging tactics.:yes:
tiler
UKTT Darren
TF Official Sponsor
Subscribed
195
828
North East
Reps are all about selling their own products and im wise to that anyway, i did tell the rep that i wasnt convinced at the time anyway, im familiar with the durabase wp so new what the pci,s capabilities probably were. The heading i put wasnt to endorse the fact only to open a thread for discussion from what info was given from the rep
Reply to PCI PECILASTIC instead of ply in the British & UK Tiling Forum area at TilersForums.com
no more ply have recently added a new board, so heres an updated version NO MORE PLY...
7K
Aston
just a quickie starting a job monday, and they have the polyplumb overlay stuff in, which, from...
7K
Gazzer
Has anyone used this, I seen it on vista tiling for £10.50 for 1.2m2, its self adhesive, can be...
7K
Tilecentre2
Plastic ply by N&C Nicobond!! Had two bathrooms to tile walls and floors well the owner had...
2 3
19K
Marmox board info, again theres a web site and tech helpline :thumbsup: hope it helps, ed...
7K
DHTiling
UKTT Darren
TF Official Sponsor
Subscribed
North East
    Votes: 14 9.3%
    Votes: 11 7.3%
    Votes: 44 29.1%
    Votes: 18 11.9%
    Votes: 36 23.8%
    Votes: 21 13.9%
    Votes: 18 11.9%
    Votes: 16 10.6%
    Votes: 7 4.6%
    Votes: 4 2.6%
