Discuss Peeling Primer on skim (BAL APD) in the British & UK Tiling Forum area at TilersForums.com.
BathroomJockey
Good evening all,
A few weeks ago I skimmed our bathroom wall, let it dry (6weeks) and then primed it with neat BAL APD primer in preparation for tiling as per instructions. Once dry the primer could be peeled off easily like PVA does from your skin. I spoke with BAL technical support who advised on sanding it back, stiff brushing the dust off and re-priming with a 1:1 dilute.
So, I did the above as advised but the problem persists: If I stick a piece of tape to the wall i pulls away easily bringing the primer 'skin' with it. The wall was not dusty when the primer was applied - it was well brushed, wiped with a wet cloth and allowed to dry.
What am I doing wrong?
For information, I intend to tank it (BAL WP1) before putting up glass tiles (BAL Mosaic Fix).
Merry Christmas!
BJ
The Legend; Phil Hobson RIP
Merry Christmas to you too, imo neat primer is a no no. It will just form a skin on the surface, skim should be abraded to give a key, I don't use bal but even 1:1 seems to strong to me. I use Mapei primer G, and dilute it 3:1 the primer needs to soak into the skim to a degree, to form an anchor. Hope this helps BJ:thumbsup:
BathroomJockey
Thanks Phil,
I shall try 3:1 over 2:1 as I reeeeaaallly don't want to have to strip it down a third time!
What concentration would you do the second coat? I will be using a cement based adhesive so I want to avoid reaction issues.
bj
(sorry if this repeat-posts, being unregustered it is a bit confusing as to when these posts appear!).
BathroomJockey
Re: Peeling Primer on skim (BAL APD) - Update!!
Thank you all for your replies and many apologies for not getting back sooner.
Following your advice, I diluted the primer to (I estimate) between 1:6 and 1:8. I applied it to a test area of the wall and after approximately 15-20 coats the substrate was no longer taking in any moisture. I then repeated the "tape-test" using a lowish tack masking tape and still the skin came off easily.
I know have no clue what to do.
For information, when I originally primed the wall I also did the adjacent walls (not bare gypsum). When I do the "tape-test" on these walls nothing comes away with the tape (not even with duct tape).
Any other ideas? My sense of humour is begining to fail somewhat.
bJ
Reply to Peeling Primer on skim (BAL APD) in the British & UK Tiling Forum area at TilersForums.com
I received an email about BAL External tile adhesive and grout this morning and thought I'd post...
5K
My first big tiling job. It's a wet room and I'm at the stage where I have Marmox boards on...
Hello All, I would just like to start off by saying that I've been in the construction industry...
7K
    Votes: 14 9.3%
    Votes: 11 7.3%
    Votes: 44 29.3%
    Votes: 17 11.3%
    Votes: 36 24.0%
    Votes: 21 14.0%
    Votes: 18 12.0%
    Votes: 16 10.7%
