Discuss Pine Ply in the Canada Tile Advice area at TilersForums.com.
Glynn
473
LEYLAND
PDC is right about using ply. Ply worked well for the industry for many years but things have got better. That said, ply just doesn't just stop working for us. If you are going to use ply we would recommend a 12mm WBP or a Class 3 Flooring Grade Ply screwed at 150mm centres, Primed with an SBR or acrylic primer and tiled with an S1 or S2 adhesive. All usual checks for deflection and suitability of the substrate must be carried out first. Also check the suitability of your adhesive it may have different standards to ours.
Dumbo
pine ply also know as shuttering ply the glue between layers may be wbp but your water based adhesive
will soak into the pine delamanating the layers it will swell up and your tiles will fail easy test cut a corner
put in a bucket of water and see what happens
I believe you would get the same result with hardwood wbp as the hardwood is not waterproof only the glue .
Rizzle from the Portizzle
believing is one thing knowing anther so find out for your self cut a piece of each put them in a bucket
of water and see what happens to each and how fast .your knowledge will go up one level .
Reply to Pine Ply in the Canada Tile Advice area at TilersForums.com
  • Sticky
5K
Matthew7
Hi, a long time since I have been here but back for some advice/reassurance ! About to tile my...
I'm embarking on tiling a kitchen, wall-to-wall (under washing machine etc). most of the floor...
Pine Ply
    Votes: 14 9.5%
    Votes: 44 29.7%
    Votes: 17 11.5%
    Votes: 35 23.6%
    Votes: 21 14.2%
    Votes: 15 10.1%
