Discuss plasplugs master tiler wobbly spindle in the British & UK Tiling Forum area at TilersForums.com.
DHTiling
Very true marcus...it does seem to be a problem with the plasplug and other cheaper brands.....they do the job...but if you intend to tile for living then i would advise peeps to buy a more reliable cutter......
I have the rubi diamante d200 flat bed with split tilting table....very good machine and have had it for ages.....pricey(around the 600 note mark) but good and powerful......then i have the dw250n rail saw.....both cracking machines.......
Gazzer
I bought the Plasplugs machine a few years back and it had a wobbly spindle so i took it back to B&Q, when they gave me a new one i checked it when i got out to the car. This machine was the same, so back in and this time I and a B&Q assistant check all stock and they were all the same. I got a full refund but on the way home i stopped at Machine mart and tried a machine there, it was ok. Seems you need to try before you buy. I have had the plasplugs for 2 years now and no problems.
GazTech
i wouldnt mind betting that there have been a load of rejects made and b&q bought them all!!! bit like there tiles? alledgedly...
When I was at Topps, we had loads of little plasplugs cutters returned. The main problem was that people were using them for more heavy duty tiles, they are fine for ceramics, but give them chunky slate or trav....they give up...Gaz
tiler burden
to be fair to it gaz, its ok for power, just the spindle wobbling.
i was cutting some marble and it was fine just up to the last bit and then it would split off the line and ruin the cut. i was taking it easy, no extra pressure, but that didnt happen when i borrowed my friends cutter later on.
no probs, its not as though ive just spend 180 on it and then changed it for a masterpiuma :6:
MrSpoon
i have a 240v master tiler and a 110, the 24 works a trat but the 110 had a wonky spindle, so is a pain to be accuarate with, allways keep my right hand thumb on the edge of the tile all the way till its cut throught the tile to prevent chipping of tiles and doenst harm your if youf finger touches the wheel anyway
martyof
Hey man, I had a similar problem when I first bought my master tiler but I called the guy back and he said it was a regular problem and that it was the little discs that actually hold the blade in place as the original ones where all cheaply produced. He said plasmaplugs had sent him lots of replacements and forwarded and new set to me..this fixed the problem so hopefully this might help you too
Reply to plasplugs master tiler wobbly spindle in the British & UK Tiling Forum area at TilersForums.com
Plasplugs Master Tiler 110v for sale , Used but good condition. No guide fence ( most get lost...
Hi all, I am going to a play tomorrow night an it is about 4 tilers. Did anyone on the forum...
Wet Vs Dry polishing, which is better? We get asked this daily. There is really no definitive...
9K
Turkish tiler
For sale this plasplugs - master tiler 110v industrial wet cutter in excellent condition &...
tootall66
Hi I have a plasplugs master tiler & the supplied blade really struggles with hard porcelain...
7K
david campbell
    Votes: 9 5.7%
    Votes: 15 9.6%
    Votes: 11 7.0%
    Votes: 47 29.9%
    Votes: 19 12.1%
    Votes: 37 23.6%
    Votes: 4 2.5%
    Votes: 21 13.4%
    Votes: 18 11.5%
    Votes: 17 10.8%
    Votes: 7 4.5%
    Votes: 3 1.9%
    Votes: 4 2.5%
