Discuss plaster curing time... in the Canada Tile Advice area at TilersForums.com.
I
ian158
I'd wanting to give it a bit longer than overnight...
Agreed...Mr T...heres a plastering job I did last year..cold weather and no heating in the house...take a look at the ceiling.done the day before..see the variations of colour as its curing..the very light patches are dry.as for the wall id just finished it and as you can see very dark..in cold weather it will take a good 48hrs to dry before you can tile.
I
ian158
I didn't actully tile that wall...i tiled next to it..the walls were lime mix and literally fell off the wall..dot and dab walls with board..skimmed the walls to be painted and tiled aqua panel and bear plasterboard..in this weather with a window open..as it sweats so unless you have air circulating it will take longer to dry..but as said depends on weather...temp..air flow and what your skimming on.
Reply to plaster curing time... in the Canada Tile Advice area at TilersForums.com
Hello, looking for advice and what to do next. Have had main bathroom installed via a local...
I used Micromax 2 for the first time a few weeks ago and all was fine, the next day it was rock...
5K
One Day
Hi all, I applied Tile Master PrimePlus Flexible Primer around my bath and sink and for some...
11K
chrisb1357
in the bathroom I am doing its an ex council the walls are bad ( pretty sure the council only...
5K
N A T
N
    Votes: 14 9.5%
    Votes: 44 29.7%
    Votes: 17 11.5%
    Votes: 35 23.6%
    Votes: 21 14.2%
    Votes: 15 10.1%
