Discuss plaster primer in the British & UK Tiling Forum area at TilersForums.com.
akinsontiles
Be cautious about the weight limit with those tiles 20kg max including adhesive and grout onto skimmed plasterboard.
Fast set mapei adhesive doesn't tell me the type of adhesive. I take it that it's a cement based one suitable for walls as well as floors by the sound of it. I would recommend one such as P9 or P10 for large format on the walls with back buttering a must.
You are quite right using a primer as the cement would react against the gypsum and not bond correctly causing it to come off later on.
akinsontiles
yeah back buttering simply means serate the wall as normal and spread adhesive over the reverse side of the tile so that you get 100% coverage and its bonds adhesive to adhesive rather than adhesive to ceramic/porcelain. Good practice to follow on all jobs to avoid failures but especially important on large format tiles or those with ridged markings on them from the kiln process.
Was that data sheet any good for the primer you got or was it a different product?
Reply to plaster primer in the British & UK Tiling Forum area at TilersForums.com
I have the old stock no more ply down unprimed. (Their new stock comes pre-primed). Mapei...
Hi, in anyone’s experience, would gypsum plaster irreparably stain marble tiles? In my bathroom...
Some helpful advice/opinion would be appreciated... Existing tiles on walls, some of the walls...
Hi, can anyone advise me on how to prep a painted brick or block wall for tiling? Do I just wash...
Hi am re tiling kitchen and want some ideas as to what’s best to repair the walls after Remiving...
plaster primer
    Votes: 14 9.3%
    Votes: 11 7.3%
    Votes: 44 29.3%
    Votes: 17 11.3%
    Votes: 36 24.0%
    Votes: 21 14.0%
    Votes: 18 12.0%
    Votes: 16 10.7%
