Discuss plasterboard ceiling in the Canada Tile Advice area at TilersForums.com.
cfrazerg
Hi,
The old house i just bought had polystyrene tiles which I removed unfortunately the old adhesive will not come off from just scraping that was used to dot and dab the poly on. Ive been told to plasterboard over it should I dot and dab new plasterboard above the old ceiling or pull the old board down and put new plasterboard down and screw it down.
Protilers
IMO....pull it down......ceilings are always located on stud (they have to be).........even if it is lathe and plaster....either way....its quicker to get above and "kick" it in!!!!!!!.........and it is better!!!!
once you are back to joists........12.5mm plasterboards........with a tapered edge.........bit of filler and you are good to go!!!!!!...
Lee
Reply to plasterboard ceiling in the Canada Tile Advice area at TilersForums.com
Hi all, I am in the middle of renovating my bathroom. First of its kind for me! The walls were...
Hello. First time tiler looking for some advice. Doing a bathroom reno and had a professional...
  • Sticky
Hi all, I'm part re-tiling/plastering a bathroom, which as the pictures show, has masonary to...
    Votes: 14 9.5%
    Votes: 44 29.7%
    Votes: 17 11.5%
    Votes: 35 23.6%
    Votes: 21 14.2%
    Votes: 15 10.1%
