Discuss plasterboard on studding in the Canada Tile Advice area at TilersForums.com.
topgun
Hi all,just started bathroom refurb on our new house.I knew all was not well as the tiles were bulging of the wall & water came through the kitchen ceiling if the shower head pointed anywhere near the wall!
My query is which material to use to replace the damaged plasterboard.
The room is in a dormer & was vapour check p/b.
Should i use plasterboard,moisture p/b or aquapanel
AliGage
Subscribed
4,531
1,188
Peterborough, England
If your weight on tiles is within limits for plasterboard then i'd re-line and tank/waterproof.
Use a good quality grout, and it doesn't hurt to seal the grout joints after as well. If water is leaking through when the shower is directed at it, chances are it's penertrating the grout.
If the timbers have absorbed some water give it time to dry before lining.
Reply to plasterboard on studding in the Canada Tile Advice area at TilersForums.com
  • Sticky
Hi. My daughter is having a walk in shower fitted by builders. I am concerned because most of...
Notts_Rob66
N
Hello all. I'm doing a total refit of my bathroom, including the floor which is water damaged...
Hi, Looking for some advice.... A returning client has came to me in a bit of a dilemma and...
16K
lizzardtong
L
    Votes: 14 9.5%
    Votes: 44 29.7%
    Votes: 17 11.5%
    Votes: 35 23.6%
    Votes: 21 14.2%
    Votes: 15 10.1%
