Discuss Plasterboard or Cement Backer Board in the UK Tiling Forum area at TilersForums.com.
mmmadman
Hi All
DIY question on my ongoing small bathroom refurbishment.
I have started removing the existing tiles and they are so well stuck on that they are pulling chunks of plasterboard away, leaving a very uneven surface.
I have decided to take of the whole lot, boards and all and start again.
What should I use, plasterboard or cement backerboard. The walls will be tilled floor to ceiling using 420mm x 300mm ceramic tiles.
I favour 6mm cement backer board, the 12mm seem overkill to me..........!!!!!!
Cheers...................:8:
Reply to Plasterboard or Cement Backer Board in the UK Tiling Forum area at TilersForums.com
Hi all - I have some small format ceramic tiles (10x10x1cm) to use as a splash back around the...
Hi Everyone, I have recently started the task of renovating the bathroom in my flat and am at...
