Discuss Plastering and tiling over existing tiles in the UK Tiling Forum area at TilersForums.com.
UK
Some helpful advice/opinion would be appreciated... Existing tiles on walls, some of the walls we want new tiles on and others we want plastered ready for painting. Can anyone tell me how much longer it would take to remove the tiles and make good the wall then plaster and/or re-tile compared to leaving the old tiles on and plastering or tiling over them? If you could give me pros/cons to both approaches that would be great too! Thank you
Like @Dan has said, we would recommend pulling it all down and then putting up a tile backer board which is a lightweight cement fibre board meant for creating a flat surface to tile onto. Our preferred brands are Marmox Multiboard and Orbry Board. These boards can be fixed to the wall with screws or with adhesive.
Reply to Plastering and tiling over existing tiles in the UK Tiling Forum area at TilersForums.com
Seems alot of talk that 20kg per mtr2 is the max weight limit for plaster. Few questions 1. its...
    • Useful
Hi, Im looking for a recommendation for a liquid tanking. I have to use a liquid tanking...
Tilers Forums on FB
