sachinj
Hi guys, i need some advice from the pros!
I'm re-doing my bathroom but not too sure which way to go with the flooring.
The floorboards are in pretty bad shape and have warped a fair bit. Want to take them out and lay some plywood down instead. My question is; will 18mm WBP plywood screwed down at 400mm centres be ok?
I would love to be able to get away with 18mm as once everything is down, it should be near perfectly level with the landing floor (cheaper too!).
Thanks in advance for any help.
Sachin
Sachin
