Discuss plugs for porcelain in the UK Tiling Forum area at TilersForums.com.
TMTservices
What plugs do you guys use for hanging heavy items onto porcelain over plasterboard?
Returned to a job today to get paid and plumber has made a right hash of hanging a shelf and cleared off on holidays.
Shelf needs 2 holes either side and he's drilled one 10mm hole next to a 6mm hole, and on opposite side we have an 8mm hole and a half drilled 8mm hole. lol.
what plugs would you use? Theres a reasonable amount of weight in the shelf too.
Thanks.
Deleted member 1779
We also recommend using
Red plugs for 6mm
Brown plugs for 8mm
Both the 6mm and 8mm are available from our site as diamond core hole saws
Here shown drilling 8mm holes into very hard porcelain tiles:
The 6mm and the 8mm cores come with either a £29.99 pack
Or for an extra £20 quid you get the full pack above which has the large cores.
They are 16mm 30mm and 40mm diamond holesaws.
The 16mm is perfect for drilling 5p sizes "cores" or "plugs" out of a tile for rawl plugs.
By making a fairly large hole in a tile the fixing is sure not to rest on the tile.
In this project the hole is open up to 16mm and a 10mm anchor bolt pushed in (Size M6 or M8)
As you can see the rawl plugs of 10mm 12mm 14mm will all fit a 16mm diamond core hole
Above you can see the size is 16mm (marked in pen bottom left)
The bolt shown through the tile doesnt catch the tile
The rawl plug (grey) is 14mm and slips though the 16mm hole.
But for small holes only we carry the 6mm and 8mm packs
Above shown a series of 8mm holes for
1) Toothbrush holder
2) Soap Dish
3) Toothbrush Glass
Deleted member 1779
Red plugs for 6mm
Brown plugs for 8mm
Sorry guys yes to clear up any confusion (or maybe to add to it....)
We were trying to say:
Red plugs [at 5.5mm/6.0mm] for use with our 6mm diamond cores
Brown plugs [at 7mm] for use with our 8mm diamond cores
We do kind of get a bit shorthand and really when it comes to the 6mm diamond cores and the 8mm diamond cores of course there are a range of rawl plugs and colours that fit with our brand
but we try to show the difference and its easier to say 6mm is red and 8mm is brown.
There I think I have really muddied the water... (I dont think I even understand my own post) :lol:
Reply to plugs for porcelain in the UK Tiling Forum area at TilersForums.com
Hello! We have an issue with 12 cracked large format thin porcelain tiles (1500x1500x6mm). They...
Hi all, Have a question about how/when best to install tile trim - probably quite basic! One...
23K
Deleted member 57709
Hi Tilers, this is my first question on this forum and I've got a few different areas to cover...
Q
    • Winner
    • Informative
So I was recently asked to fit some 3m x 1.5m 6mm thin porcelain in a new tile showroom. Mapei &...
8K
Qwerty
Q
TF Group Please Join
plugs for porcelain
Tilers Forums on FB
