Discuss plywood fitting. in the British & UK Tiling Forum area at TilersForums.com.
davey-j
hi, when boarding out a floor with ply do you, usually take out the toilet and sink?
Only asking because i was thinking it would be awkward to cut ply round the fixtures.
Also if the pipes go into the wall how would you combat this as putting ply down will lift the floor thus the pipes will not be in their original place. All help much appreciated thanks.
F
faithhealer
In a perfect world whip the lot out davey (is this a customers house, price might be a factor) but check first what the increase in height is going to do your fittings. Wash basin height, flexis not a problem, if in copper, fit an isolator valve to add height. Traps can be bought with adjustable heights. Pan connectors can be brought with an offset in.
davey-j
Its basically my brothers house, im not over familiar with the different pipes that are fitted to sinks , toilets. Their just white plastic pipes that go into his wall from the sink waste hole, and the toilet i suppose a flexi pipe can be bought. . if the pipes are of the copper kind coming up from the floor, obviously where the water comes from can extenders be bought to lengthen the pipe?
Sorry im new to all this:dizzy2:
F
faithhealer
toilets. Their just white plastic pipes that go into his wall from the sink waste hole,These are your waste pipes,
and the toilet i suppose a flexi pipe can be bought.\this is your pan connector
. if the pipes are of the copper kind coming up from the floor, obviously where the water comes from can extenders be bought to lengthen the pipe? This what I meant by isolation valves, about 12 quid for a pack of ten at bQ, cut the pipe and use a spanner to tighten the valves on
Please pm me davey if you get stuck
Reply to plywood fitting. in the British & UK Tiling Forum area at TilersForums.com
Hi All, I’m ripping out a failed existing tiled floor. Tiles had not been back buttered so...
Hi I asked the Wunda technical department if I can just use a Ditra mat only and not the SLC...
plywood fitting.
    Votes: 14 9.3%
    Votes: 11 7.3%
    Votes: 44 29.1%
    Votes: 18 11.9%
    Votes: 36 23.8%
    Votes: 21 13.9%
    Votes: 18 11.9%
    Votes: 16 10.6%
    Votes: 7 4.6%
    Votes: 4 2.6%
