Discuss Plywood floor, tile gap in the British & UK Tiling Forum area at TilersForums.com.
mercedism
I have laid plywood and left a small gap around edge. Once tiles are laid there are certain areas where skirting will sit over it and there are other parts where units will sit over it. But there will be small gaps.
As there are air bricks in the outside wall, what do i use to seal up the edges? Do i use a good low modulus silicon as don't want to waste heat and it too become drafty in there?
mercedism
I have roughly set out and didn't want to go hard upto the walls. So if i leave a gap around the perimeter, certain walls will have no kitchen units against them so i can fit skirting over the top and seal there if need be.
But there will be units over some of the others, what i don't want is an air gap. I would like to think 10mm gaps would be the maximum, but if you suggest smaller i will make the cuts tighter.
Deleted member 1779
I would also agree.
If you have laid ply over boards, and left a small gap between the ply and the external wall then Silicon would be fine to plug the gap.
Anything bigger then I would be squirting "no more big gaps" into the holes.
I did that to fill in the gap on a floor joist which was too small to get any stuffing into it. The rest of the gaps I filled in with lagging.
But I think you are only talking about a gap of a few milimeters. However if you can get the gaps plugged up ahead of the game thats going to do the best long term job.
I also found by lagging inbetween the floor joists that it cut out a lot of sound. But then its my own home so I wanted to spend the money. For a customer its probably overkill.
Reply to Plywood floor, tile gap in the British & UK Tiling Forum area at TilersForums.com
Been advised to move this post to the uk forum, didn’t realise it was in the USA forum Would...
    Votes: 14 9.3%
    Votes: 11 7.3%
    Votes: 44 29.1%
    Votes: 18 11.9%
    Votes: 36 23.8%
    Votes: 21 13.9%
    Votes: 18 11.9%
    Votes: 16 10.6%
    Votes: 7 4.6%
    Votes: 4 2.6%
