Discuss Plywood in tiling in the Canada Tile Advice area at TilersForums.com.
I
Ian
This is a subject that usually causes a bit of a stir but, I'd like to see what everyone thinks. With the exception of replacing floors onto joists, is there really a place for ply in tiling anymore? There are so many better products to use as an alternative to ply. Then there's the question of how thin can you get away with?
John Benton
1,138
Leeds
I saw a builder fitting a bath made out of ply the other day, fitted loads and never been called back he told me!!!
Not really, but I only use backerboard now, feel more comfortable after seeing plywood damaged by water in the past!!!
Ollie02948
I used ply about 3 years ago on a job. It was a small bathroom floor approx 5sqm. Over boarded with 18mm ply. Customer phoned up about four months later saying floor had hairline crack of about 18inch on a tile. It had done it where two sheets of ply had joined together. I ripped up whole floor reboarded with hardie and then re tiled. It's been fine ever since, I learnt the hard way, I still don't understand why people don't take the advice of not using it.
widler
1,328
England
I wouldnt use ply, only as a underlay for cement boards.
Ive never used ditra though, how is a mm or so of plastic going to stop tiles cracking if the ply swells ? Wouldnt screwing of cement board be better, at least if the ply gets damp the screws and glue would stop it from moving to much, id not ditra only guaranteed for a mm or so of movement ?
Just curious in my little head that is all !
Reply to Plywood in tiling in the Canada Tile Advice area at TilersForums.com
Hi, I recently purchased my first property and the existing kitchen floor porcelain tiles were...
benchwarmer
We just had a 1.5 sq. m area of floor tiled professionally in our ensuite. The base floor is 18...
Ok. Basically am i tilng right/prepping correctly? Full time professional tiler, nearly 15...
benchwarmer
Plywood in tiling
    Votes: 14 9.5%
    Votes: 44 29.7%
    Votes: 17 11.5%
    Votes: 35 23.6%
    Votes: 21 14.2%
    Votes: 15 10.1%
