Discuss Plywood walls in bathroom in the Bathroom Tiling Advice area at TilersForums.com.
Dr_Gonzo
Our builder has just finished our renovation project and he has boarded the bathroom out with plywood. After some research I now know that this is far from the ideal surface to tile onto. The ceramic tiles we have are pretty large (900x300) and are 10mm thick. It's quite a large bathroom (i.e. several sheets of ply) and we have a concealed shower recessed into the wall. Given the plywood is in, what is our best option now?
martin1c
633
Cheshire
For what it is worth, your best bet is to replace/overboard. Those size tiles will have cost you a small fortune so you'll want the best chance of them staying up on the walls for years to come. Removing/replacing the ply won't take long and doesn't cost much. A sheet of plasterboard is only £6. I'll bet it could all be replaced/boarded over within a day
Stef
Im with Martin on this one.
Your builder would have already strapped out the walls to take the plywood so you should be able to fix the plasterboard straight onto these, (almost)
The only thing you might find is that a sheet of plywood is 1220mm X 2440mm, (if he has used full sheets) so your stud/straps will be set for this, if this is the case then just fix an additional length of wood onto the side of the existing legs to carry the sheets.
Its not a hard job replacing the plywood, it will be a harder & more expensive job if you fix those tiles to ply in a humid environment like a bathroom.
Reply to Plywood walls in bathroom in the Bathroom Tiling Advice area at TilersForums.com
We had our loft bathroom done a month ago and are having issues with the tiler (recommended on a...
Vinny Kehoe
V
TilersForums.com has been online since 2006 and we've had many designs, even three forum...
Tilers Forums on FB
