BILLY BENAWRA
Hello,
I am new member of Tilers Forum.
I used to make custom made lighting using hand blown glass extruded tubes from Murano Italy.
I want to design a new column lamp using polished quartz slab 100mm x 100mm or 120mm x 120mm as a base with hollow reeded glass tube.
I have 2 questions -
From where can I get 100mm x 100mm quartz slab WITH polished edges?
If I were to cut the quartz slab myself with a diamond tile cutter, is there an easy way I can polish the edges?
The thickness of the slab is about 10mm - 12mm and I am going to use round polished glass discs as feet of the lamp using Boehler UPV glue.
My next project will be to design a mini-bar tray using quartz tile (square and round) with small brass pillars and brass rail all around the edge of the tile.
Again the edges require polishing for a good presentation to 4 or 5 star hotels. The bottom of tray will be with felt so furniture does not get scratched. Can someone support me with some nice colour quartz tile samples?
I will appreciate to receive your comments.
Billy
Billy
