Discuss Polishing silver trav in the Australia Tiling Forum area at TilersForums.com.
K
kaharrison9
Good Evening All
Just on with a bathroom in silver trav at the moment that requires quite a bit of bullnosing/polishing.
I have used the same formula as I would with mid trav - stone router then 80, 220, 400 Silicon carbide paper but with this stone i'm having difficulty matching the finished appearance with the face of the stone.
The bullnosed area looks faded and flat and you can see a clear contrast between the 2 surfaces.
When wet the 2 look equal.
Any thoughts? Do Lithofin does a enhancer that does not give a wet/gloss look?
Cheers.
Kevin
Concrete guy
400# silicon carbide is a honed/satin finish, you'll need to go further with 600, 800 and maybe even 1200 to bring up the polish to the same degree.
Chemicals won't help, it's a mechanical polish you require.
Also be very sure to spend long enough getting the tool marks of the profiler out, they will show more as the polish is increased.
K
kaharrison9
Apologies it is honed.
400 on slow speed is the highest grade I can go otherwise it starts to polish, yet it looks as though it needs a high grade to bring the colour through.
Have tried Lithofin Colour Intensifier on the edge and it seems to have worked a treat and blends the face and edge in well.
Cheers guys
Reply to Polishing silver trav in the Australia Tiling Forum area at TilersForums.com
Wet Vs Dry polishing, which is better? We get asked this daily. There is really no definitive...
9K
Turkish tiler
11K
Rizzle from the Portizzle
I am beginning to set some travertine in a spa room and have a few questions. We had some 38mm...
Have lots of unusal display stuff - Travertine Columns - Egyptian Hieroglyphic Freeze 90 x...
Stonebro2
7K
Stonebro2
    Votes: 9 6.3%
    Votes: 13 9.0%
    Votes: 9 6.3%
    Votes: 44 30.6%
    Votes: 17 11.8%
    Votes: 34 23.6%
    Votes: 3 2.1%
    Votes: 20 13.9%
    Votes: 18 12.5%
    Votes: 15 10.4%
    Votes: 7 4.9%
    Votes: 3 2.1%
    Votes: 4 2.8%
