Pool pump advice Discussion ThreadPool pump advice Electrical Advice
Hi all! Im having an issue getting an electrician to my place before the holiday. My pool is filled and ready to go. I have ran the grounding bond wire and connected it to 4 spots on the pool. The filter has a bonding plate inside and then to the pump itself. I need to run a new circuit. Just need clarification as i have never ran a pump circuit. The pump is 120v 10amp 60hz
20amp single pole gfci breaker with 12 gauge romex to exterior wall into a weather protected box transitioned to thhn fed into pvc 12” underground to a gfci outlet.. from the gfci load to a twist lock receptacle (will a 20a 125v double pole work?)
Pool pump advice for the original thread on Electricians Forums
