Discuss Porcelain and ditra in the Australia Tiling Forum area at TilersForums.com.
rj1884
Good evening. Quick question if I may. I know it's probably been spoken about on many occasions on the forum so I apologise in advance. Went to a job the other day 30m2 of the parquet style tiles from porcelonosa. The existing flooring is being removed back to the original screed which I believe is a sand and cement screed. The house is very old. My question is is if the screed is good with no cracks would you recommend tiling straight to the screed or would you want to put ditra down as well for extra piece of mind. I know for natural stone it's a must but some views differ with other tiles.
Thanks in advance.
White Room
The chances of any movement on the screed after that length of time will be pretty slim, I would want to check to see if there are any hollow areas before making any assumptions after the existing floor has been taken up.
If there any cracks these would have happened years ago, I have tiled directly to old screed floor and it's been sound.
Reply to Porcelain and ditra in the Australia Tiling Forum area at TilersForums.com
hello new here but wished i had found and asked before screed and ufh down but here goes. We...
Hi All, I’m ripping out a failed existing tiled floor. Tiles had not been back buttered so...
Hi all, Will I be setting myself up to fail if I use the Dunlop CF-03 Flexible Fast Set Tile...
Porcelain and ditra
    Votes: 5 4.0%
    Votes: 11 8.8%
    Votes: 8 6.4%
    Votes: 35 28.0%
    Votes: 16 12.8%
    Votes: 31 24.8%
    Votes: 3 2.4%
    Votes: 2 1.6%
    Votes: 19 15.2%
    Votes: 18 14.4%
    Votes: 14 11.2%
    Votes: 6 4.8%
    Votes: 3 2.4%
    Votes: 2 1.6%
