Discuss Porcelain Mosaics and Bal Grip in the UK Tiling Forum area at TilersForums.com.
jgw1
Cheers,
I chose a 6mm trowel because the wall isn't dead flat from taking off the old tiles.
I didn't want to mix for two reasons. 1. I am not the fastest tiler and I know that this will take time to get right - so thought using addy from a tub would mean I could just apply what I need as I go along. 2. I have used powders before and just wanted to not have the fuss.
What about Bal Mosaic? Is BAL SPF flexible suitable?
jgw1
OK I might go for BAL Rapidset flexible because that comes in a 10Kg grey bag. With BAL Prime APD onto the plasterboard which I will level off with some skim tonight.
Is it defo a 4mm trowel or is a 6mm fine but with more cleanup required? I have a 6mm and don't really fancy having to buy another for a 3.5sqm DIY job. But the advice I have had here has always been good so if you say 4mm it will have to be 4mm.
Reply to Porcelain Mosaics and Bal Grip in the UK Tiling Forum area at TilersForums.com
Hi, can I use BAL Quickset Render to level and area between Hardiebacker and drywall then cover...
Hi, I‘ve just finished tiling the majority of my garden path. Base is concrete, and tiles are...
