pevro
Hello there,A bit of advice for a scared newb.Heres the scenario, purchased Topps black and white Salvatore floor tiles along with Bal Single Part Flex adhesive and Bal Superflex Wide Joint in Charcoal. Topps advised removing wax coating so used Lithofin WEXA. Then proceeded to apply Lithofin Protective Impregnator to tiles after fixed.Now I proceeded to grout m2 sections but after rinsing the excess the white floor tiles have what i can only describe as a dirty wish wash effect that appears to be under the surface of the tile. I stopped after about 4 m2 (half the floor area) am now stuck with half the floor grouted with stained white tiles and half the floor un grouted but scared to proceed in case of ruining the whole floor.Topps said it sounded like the protective wax coting was still present and advised to strip with Fila stripper - this hasn't worked.Bal Technical support suggested a Emulsifying pad and warm water. Failing that Nitromors !! The guy there said that the grout neaded to be treated now almost like an Epoxy Grout. After a pretty liberable application of Nitromors and working with various scrubbers, this doesn't appear to have worked either.So the questions, are the tiles mullered and only option is rip up and re lay. Or is there a magic solution to the problem.Also in the worst case scenario that the tiles have to come up, what can I use to prevent this happening again and to the rest of the tiles.Thanks in advance
