Discuss porcelain tile cutter in the Tile Cutters (Manual & Wet Cutters) area at TilersForums.com.
do i need a special tile cutter for
porcelain floor/wall size 330X500mm 8.5 mm thick
i will be putting them on the bathroom walls
I've got the same cutter,it cut 600x600x8mm porcelain with the 10mm that came with it no problem.ive been using a genisis 600mm cutter with rubi 18mm wheel for cutting had no probs on any porcelain not bad £120 quid £10 for the rubi wheel darren at NETT supplies them!
were do you get them wouldnt mind a look at it!
Reply to porcelain tile cutter in the Tile Cutters (Manual & Wet Cutters) area at TilersForums.com
