reeves1985
I'm building a custom vanity unit to fit into a space which is looking great so far.
When looking around for ideas for the top and like the idea of a tiled top but didn't like having joints or grout lines (it would look silly as its only a small cabinet and space) I've realised I can get the desired effect using just one 60x60 tile (great)
So I have the tile I will need to trim 3 edges which I have a cheap wetsaw I'm sure can do that as the don't need to be perfect as the cut edges will be hidden.
My question is:
Without getting all fancy Dan and buying anything expensive for this one cut what is the best method to cut the hole for the basin.
It doesn't need to be a brilliant and can be crude because the edges will be covered as the basin is a ouvermount type.
I have a angle grinder, a cheap wet cutter, a dremel
Oh and the tile is 10mm thick
Thoughts ?
My question is:
Thoughts ?
