Discuss Porcelain Tiles - Problems! in the Canada Tile Advice area at TilersForums.com.
Chris101
Good Evening,
I have just had my kitchen tiled - around 40m2 and am worried about the following -
1. How level the actual floor is
2. Multiple small chips on tiles laid (I have counted 10 so far and only counted 30% of the tiles laid)
3. A few of the tiles are raised by 2mm
4. Some of the grout lines are either too small or too big (consistency), should all have been 3mm
5. Gaps between skirting and floor (only in some areas but been told this is to allow the under floor heating expansion).
We have a concrete floor with wet underfloor heating and screed on top.
The tiles were laid on top of a decoupling membrane and has been down for over a week.
Should the above points be raised ?
What steps are required to remedy the issue.
WetSaw
There shouldn't be any chipped tiles.
Lippage should be minimal but British Standards are quite generous so you may struggle with that point.
Grout lines can vary if the tiles are not rectified or the same size, again British Standards allows a fair amount of leeway.
Having said that, regardless of what I'm working with the end result should be a happy customer.
Chris101
a few pics and yes unfortunately again as I am unsure of what action to take, if any...
20170918_212802.jpg 20170918_212619.jpg 20170918_212454.jpg 20170918_212813.jpg
Reply to Porcelain Tiles - Problems! in the Canada Tile Advice area at TilersForums.com
450 x 450 porcelain tiles were laid on the bathroom floor recently. One of the tile sometimes...
A question about mitering and matching epoxy colour I'll be working with some pinkish matt...
    Votes: 7 5.2%
    Votes: 13 9.6%
    Votes: 8 5.9%
    Votes: 39 28.9%
    Votes: 16 11.9%
    Votes: 33 24.4%
    Votes: 3 2.2%
    Votes: 2 1.5%
    Votes: 20 14.8%
    Votes: 18 13.3%
    Votes: 15 11.1%
    Votes: 7 5.2%
    Votes: 3 2.2%
    Votes: 3 2.2%
