waynestores
Hello to all you Pro's,
I've got a job on which is Porcelain tiles 300mm x 600mm x 10mm thick to fix into two bathroom floors, the floors seem to be plywood and are fixed down securely, could someone inform me as to which "BAL" adhesive i should be using, as I've had mixed reports from tiling shops. As these tiles are approx 10mm thick, will I be able the cut them with my Rubi TS50 dry cutter or will they all have to be wet cut? Which grout should I be using, I'm using 4mm spacers...
