Discuss Porcelain wall tiles - fixing in the UK Tiling Forum area at TilersForums.com.
davmar44
Hi all and thanks for looking and your help.
We have just had an extension built, most walls are solid and have been boarded and skimmed. Couple of small area stud walls again boarded and skimmed. Approx area to be covered in total 95 sq mts
We have bought sealed Spanish porcelain tiles approx 12" x 24" and our stupid builders have spotted them with adhesive in six dabs straight on to the untreated plaster.
Result - yes you are right, after a couple of days they have fallen off and in the main the dabs are still damp.
Obviously the walls should have been PVA'd which I have now done myself but what should I now look out for in the way they are being fixed?
Thanks for your help guys, David
Deleted member 9966
Thanks so far folks - it is only a very weak pva that has been brushed on so presumably they will be able to prime over this? The main adhesive they have used is Palace Supergrip Acrylic. Obviously they are having to replace broken tiles and retile for nowt but I want to make sure they do it correctly
ready mixed & tubbed... not the correct adhesive in my opinion
davmar44
Thanks to both of you - have printed out the primer thread so they can deal with that tomorrow and have spoken to them and told them what adhesive they are to get - and told them to talk to a professional tiler and stop trying to be all things to all men - and master of few!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!
DHTiling
You have 600 x 300 porcelain tile and tubbed( dispersion) adhesive isn't suitable for the format and type of tile.
You will deffo need a modified cement based adhesive to create a bond and higher tensile strength than the disersion one.
weight wise..not many porcelain will be to heavy for skimmed unless the are over 8mm thick..then they will need weighing.
Here is a weight guide that is floating around the forums..
Tiles and Adhesive Weight Per Square Metre - THE TILE SOURCE
Time's Ran Out
Have all 95mts been taken off because if not you should be getting that done before you start to retile.
The adhesive that they have used will not dry for days if ever so you should find it easy to clean up.
My concern is do you have the confidence in this builder to provide you with the the finished result that you require.
95mts is a large area for 'Jack' to undertake!:thumbsup:
Timeless John.
Bolter
Timeless John.
Just to stress that, 95mts is a very large amount of tiling. For a proffessional tiler I would expect that complete in 5-8 working days (maybe more) depending on what you are having done, just so you can see the time scale and size of the job. If these guys dont know too much it could take them weeks, and then not look all that great.
If they can provide you with a guarantee for the tiling as per British Standards (which is only a guideline) then I would be more happy if I were you, but thats even if they know the standards and why they are in place.
Good luck! And dont be afraid to ask for help! :welcome:
davmar44
Thanks to all of you. The builders have been told in no uncertain terms what they should be doing and, because of all your comments, taken proper professional advice which of course mirrors all that you have said.
They are removing all the tiles and the professional is sorting out primer and adhesive - I just thank God that I found you through Google - you have turned what could have been an almighty catastrophe into, hopefully, a triumph as the rest of the work done is superb.
Again a heap of thanks to you all for your time and trouble.
David
Bolter
David
Good stuff! :thumbsup:
Reply to Porcelain wall tiles - fixing in the UK Tiling Forum area at TilersForums.com
    Votes: 9 6.3%
    Votes: 13 9.0%
    Votes: 9 6.3%
    Votes: 44 30.6%
    Votes: 17 11.8%
    Votes: 34 23.6%
    Votes: 3 2.1%
    Votes: 20 13.9%
    Votes: 18 12.5%
    Votes: 15 10.4%
    Votes: 7 4.9%
    Votes: 3 2.1%
    Votes: 4 2.8%
