John the tile
Hello all
Im tiling an upstairs bathroom wooden floor. Ive not done a floor onto wood before but as long as I know exactly what Im doing im confident I can do it no probs,.. Ive been doing lots of research and have some questions.
The floor is at the moment chipboard. There is deflection (bounce) and creaking (loose nails). I do not know what thickness the chipboard is. Im guessing its either 18 or 22mm thick. The house was built in the last 15 years.. The bathroom will be empty no bath suite in...
1) Does the chipboard defo need to come up.? ( floor less than 2 square meters).
2) What is the purpose of 18mm wbp ply. Is it to make the floor have no bounce and be more rigid??? Does the chipboard not do this if its securely fixed?
3) What are the purpose of the noggins at every 300mm and at the joins/cuts of the 18mm wbp plywood? Is it also to make the floor have no bounce and be more rigid???
3a) What are the correct screws and does it matter how many I use ( the more the better?)
4) What are 6mm Hardie backer boards purpose - to make a stable surface to tile onto? What does stable mean?
4a) Do I HAVE to use hardie backer boards. Will it not be ok to tile onto the 18mm ply? Even without the hardie backer board the floor will be 15mm TOO high.....
5) Are chipboards easy to saw through with a normal hand saw whilst their on the floor? (dont want to buy an expensive circular saw just yet)
6) Ive read to primer UNDERSide and edges of 18mm ply. Why is this?
7) Is mapei G ok for the priming and what about the upper side?
8) Is mapei flexi rapid and ultra colour plus ok for the grout and addy. (ceramic tiles)
9) What are the ideas and suggestions for the floor being 15-20mm higher than the carpeted hallway? Is there a seperation floor strip I can buy?
Thanks for any answers to the above...
