Discuss prep travertine in the British & UK Tiling Forum area at TilersForums.com.
DHTiling
Hi groucho mate...i would prime the floor first...also check how flat the floor is as well......dita mat is an uncoupling and crack isolation membrane so i dowt it very much ....make sure the tiles have a solid adhesive bed then no probs...if you are going to use ditra then only use normal set adhesive on top of the ditra and never flexi......dave..
Andy Tiler
1,043
manchester
hi groucho if u dont prime the floor ur adhesive will dry quicker once u spread
it on the floor also useing the correct primer gives it a better key to the floor
so ur not just sticking to dust also u can use flexi adhesive on ditra matting
but u are just wasting ur money if u are fixing ceramic tiles but if u are fixing
porcelain tiles on to ditra it needs to have porcel bond in the adhesive or use
flexi adhesive u need to use what adhesive suits the tile not the ditra
hope this helps :wink_smile:
DHTiling
First of all the primer helps create a good surface for the adhesive to bond to especially if it was a dusty one and stops the floor sucking the moisture from the adhesive to quickly.........as regards to the ditra then read this as well...[DLMURL]http://www.schluter.com/p/content/FHB.pdf[/DLMURL]
and then here's the ditra installation handbook it will tell you everything you need to know about ditra........dave..
http://www.schluter.com/media/brochures/schlueter_hb_ditra_us_2007.pdf
Reply to prep travertine in the British & UK Tiling Forum area at TilersForums.com
Hi, Soon to lay 500mm sq tiles onto screeded hall/kitchen floor 25m2. Hall floor has vinyl...
Hi all, Was looking for some advice in regards to micro-cracks appearing on the SLC on top of...
  • Question
Hi all, we are tiling our wet room bathroom. Loft conversion, chipboard flooring, tile backer...
Hi guys, 1st post so apologies if I’ve missed any key info. We’ve had liquid screed laid 2...
prep travertine
    Votes: 9 5.4%
    Votes: 17 10.2%
    Votes: 12 7.2%
    Votes: 47 28.3%
    Votes: 21 12.7%
    Votes: 39 23.5%
    Votes: 4 2.4%
    Votes: 4 2.4%
    Votes: 22 13.3%
    Votes: 19 11.4%
    Votes: 17 10.2%
    Votes: 8 4.8%
    Votes: 5 3.0%
