Discuss Preparing a Brick Wall for Tiling in the America Tile Forum / Advice Board area at TilersForums.com.
Hi, I'm retiling the walls in the pictures which is a shower above a bath - one wall is stripped back to the bare brick and the other is back to the plaster, which is sound.
To prepare the brick wall, I'm thinking of using a 6mm hardie backer - they recommend a grab adhesive but would anyone use a bed of tile adhesive?
With either method does the brick need to be primed?
Or would anyone suggest using a different type of board?
For the plastered wall, can it be tiled straight on to, or should i put a backer board on that too?
The tiles are a 400mm x 250mm ceramic tile
Thanks in advance
Reply to Preparing a Brick Wall for Tiling in the America Tile Forum / Advice Board area at TilersForums.com
Hi Guys i’m going to be tiling over skimmed plaster walls in a kitchen for first time. (first...
Budget renovation as I just bought the flat. Cavity brick walls, 1 external. Removed old tiles...
I'm in the process of doing a small job using Hardie backer board for the walls. I've tried to...
I'm about to tile my kitchen with 600mm x 600mm porcelain tiles. I am tiling onto a subfloor...
USA Tile Forum Popular
America Tile Advice Trending
Tyrone
What member type are you?
  1. DIY Wall and Floor Tiler
    Votes: 7 5.2%
    Votes: 13 9.6%
    Votes: 8 5.9%
    Votes: 39 28.9%
    Votes: 16 11.9%
    Votes: 33 24.4%
    Votes: 3 2.2%
    Votes: 2 1.5%
    Votes: 20 14.8%
    Votes: 18 13.3%
    Votes: 15 11.1%
    Votes: 7 5.2%
    Votes: 3 2.2%
    Votes: 3 2.2%
