adam.elemental
Hello (1st post!)
I'm in the process of redoing my bathroom, and decided I'd like to have a tiled bath panel. The problem is - there is already a 2x2 timber frame there, which leaves less than 1cm between it and the edge of the bath. Previously there was a thin sheet of mdf as a bath panel.
I was planning to use Aquapanel or HardieBacker but, as the 6mm stuff can bend a bit, I should probably use the thicker 12.5mm - but then it will stick out further than the bath edge even before tiling!!
My question is - would be it be ok to use the 6mm stuff? There will be one removable access panel for the taps so that is the only bit that will ever move. Redoing the timber frame would be a painful and time-consuming option, and it would have to be done with say 1.5x2 lengths, plus there are metal supports that would get in the way....
Any help much appreciated!!
Cheers
Adam
Cheers
Adam
