Pressure test query? Discussion Thread
Hi all
I’m having to fit a Stuart Turner pump to an install that will be fed from a tank.
However, I’d like to get the install tested including the pump if possible but without it connected to the break tank, as that isn’t available at the moment.
Would I have to bypass the pump to test the rest of the pipe work or could I temporarily connect to the pump via an incoming mains?
I believe the pump operates at 1.5 bar.
Cheers
Pressure test query? for the original thread on Plumbers Forums
Hi all
Cheers
