Pricing jobs Discussion ThreadPricing jobs Electrical Advice
Hi, I'm after some more pricing help if you can, for labour costs from businesses signing off their own domestic work. I'm in the midlands. Assuming RCD and bonding etc is ok, carpet and floor access is fine, chased in, average cable length, and you can crack on, test and certificate if applicable. Thanks a lot in advance if anyone does this (copy and paste). LABOUR ONLY.
Part of UK:
+ VAT or no:
Replacing (like for like) ---
Replacing 4x socket fronts: £
Replacing 4x light switch fronts: £
Replacing 4x ceiling lights: £
Replacing 4x wall lights: £
Replacing 4x downlights: £
Replacing 1x floodlight: £
Replacing 1x 100mm fan: £
Replacing 4x smokes: £
Replacing 1x shower: £
Replacing 1x cooker hood: £
Replacing 1x oven or hob: £
Replacing 6-circuit consumer unit: £
Replacing 10-circuit consumer unit: £
Adding (to existing circuit) ---
Adding 1x socket in a room, cable: £
Adding 3x sockets in a room, cable: £
Adding 6x downlights, cable: £
Adding 1x PIR floodlight, FCU or switch, cable: £
Adding 1x 100mm fan core drilled, isolator, cable: £
Adding 1x cooker hood, core drilled, FCU, cable: £
Installing (new circuit) ---
Installing 4x smokes, cable, OCPD: £
Installing 1x shower, cable, isolator, OCPD: £
Installing 1x oven, cooker switch, cable, OCPD: £
Installing 6x sockets for kitchen, cable, OCPD: £
Installing 1x 10m SWA clipped, garage CU, 2x battens, 2 sockets, OCPD: £
Pricing jobs for the original thread on Electricians Forums
Part of UK:
+ VAT or no:
