Discuss Primer questions in the British & UK Tiling Forum area at TilersForums.com.
John the tile
Hello,
I have a few questions regarding primers. Can you use one brand name primer with another brand name adhesive. Or is this a total nono, and why??
How much primer do you give an absorbent surface, how do you know what enough is, is it just one coat?
How long after applying the primer can you tile?
Thanks for any advice - im a total newbie.
Ta
wivers
On ply i normally use a neat coat of Bal bond, on plaster board it depend on what addy yer using, if a tubbed most say you dont need to prime but with a bag of dust you will, its worth giving it a caot anyway imo, and on a plaster finish some tubbed say its okay to go direct so long as u scratch up a bit but i would give it a coating wiv Bal bond, i nornally do around 3 to 1 mix.
Y
Yorkshire Tiling Services
Usually most acrylic primers will be suitable for most brands of adhesivCheck with manufacturer or manufacturers PDF details on website.. some adhesives do not require primer.
Usually most important is priming plaster / gypsum with cement adhesives.
Prime under side of plywoood not face with most flexi adhesives
Reply to Primer questions in the British & UK Tiling Forum area at TilersForums.com
Hi everybody, I've come up with a new way that I'd like the forum to work. I've built a quick...
Hello, first post, asking about career change and possible entry route into the industry. I know...
Primer questions
    Votes: 14 9.3%
    Votes: 11 7.3%
    Votes: 44 29.3%
    Votes: 17 11.3%
    Votes: 36 24.0%
    Votes: 21 14.0%
    Votes: 18 12.0%
    Votes: 16 10.7%
