Discuss Primers and Trims in the British & UK Tiling Forum area at TilersForums.com.
grumpygrouter
I normally tile up to the door frame and then Silicon.
As for primer, currently using Ardex P51. Only cos I bought a big bucket for a timber floor job and have got loads left. Once it has gone, maybe use BAL Prime APD as a general primer. Depends on cost and how quick the stuff dries.
Grumpy
protilers
putting trims around a door is not neccesairy, just put your cuts into the frame.......this is if i understand the question properly.....as for primers,
they are usually relative to the adhesive you use, i use mapei keraquick and primer g....if you use ardex it will be a different primer etc.
good luck
andyb_987
Thanks for the replys guys.
When you say tile in to the frame do u mean that tlie near to the edge then stick the door facing back on?
Also would u give the customer the choice between putting the trim right round the door or tiling into the frame with the facing wood stuck back on if indeed that is what u do/
Cheers
andyb_987
I am saying that where the door facing is noramlly there would be tiles to the edge finished with a beads all around the door. if that makes sense.
The question is-is this ok to finish it like this ?:huh2:
I feel that it would be ok but my concern is that through time and the door constantly opening and shutting the beads would become loose.
And therefore an unhappy customer
Reply to Primers and Trims in the British & UK Tiling Forum area at TilersForums.com
I have the old stock no more ply down unprimed. (Their new stock comes pre-primed). Mapei...
Hello one and all, I have a 240m2 floor tiling job to price, including a tile upstand edged with...
Hi, first timers here... I am tiling my bathrooms and prefer the look & neatness of tiling...
Primers and Trims
    Votes: 14 9.4%
    Votes: 44 29.5%
    Votes: 17 11.4%
    Votes: 35 23.5%
    Votes: 21 14.1%
    Votes: 18 12.1%
    Votes: 16 10.7%
