V
Vw1978
Just had a plasterer in to straighten my bathroom walls out, he used bonding plaster ( this hasn't been skimmed ) to level it all out so tiling should be easier but I need to know if the bonding plaster needs priming with anything, he said use PVA 50/50 but isn't it water based? So maybe not a good idea in a bathroom? (I don't know).
My other question was - I have just purchased 25 boxes of porcelain tiles 600x300 for the walls and 5 boxes 600x300 (different tiles) for the floor, I'm wanting to stack the tiles on the wall rather than 'brick fashion' and was hoping to be able to follow the grout lines through the floor, but after measuring the tiles for the floor they aren't 600x300 as advertised, they are 597x297 which unless I make the grout lines wider on the floor it's not going to work, I know it won't work when you look at the floor from the other adjoining wall because there is 2x300 tiles meeting up with a 600 tile so I would have an extra grout line to add in, but I may have gotten away with it because of the way our suite sits you don't get to see much of that wall, so now I'm not sure what to do, do I take the floor tiles back and look for something else? (Bearing in mind it's taken us weeks to pick these) or should I try and 'brick fashion' the floor and forget about try to match in grout lines? Any ideas?
All advice appreciated.
Cheers
Another question - I have a briccolina wet tile cutter and need a new blade for it but can't find one, does anyone else use these and know where to purchase them from? The problem with it is it has two holes in the blade, one centre arbour and the other is a smaller off set hole that attaches to another bolt on the motor.
Cheers
